Fuel Pump and Sending Unit
Old Nov 22, 2023 | 11:15 AM
BlakeHolland85's Avatar
Default Fuel Pump and Sending Unit
Just was wondering whether not someone could give any insight on brands that may be worth using or not using due to issues found. Fuel gauge isn't moving all the way to full line in truck and had this similar thing happen on a dodge 1996 1500 the sending unit and pump started going bad and did this same thing. looking to purchase new and get installed hopefully.
Old Nov 22, 2023 | 5:38 PM
Please post your vehicle details, but OEM is the way to go.
Old Nov 22, 2023 | 7:16 PM
Default Vehicle Details
2005 Chevy Silverado extended cab Z71 5.3L 4x4 automatic transmission
Old Nov 22, 2023 | 10:26 PM
chem_man's Avatar
15 Year Member
ACDelco/GM Genuine, ACDelco/GM Genuine, ACDelco/GM Genuine,...
Old Nov 23, 2023 | 7:03 AM
Default chem_man
Thank you about the suggestion of what part brands, just really not hoping to get a dud. Any suggestions on the best way to get bed off the truck to change the fuel pump chem_man or mountainmanjoe? Or anyone else?
Old Nov 23, 2023 | 7:31 AM
Default Buying GM or OEM Parts and being able to find them
Just got on GMPartsCorp.com and didn't see any tank straps. ? Does GM not make those, because the one's on the tank are beginning to rot away due to cheap metals used these days and the road treatments used on the roadways the metal doesn't stand a chance to last very long. I found a fuel pump though on that site $417 thank you again about the suggestion of where to possibly find some parts.
Old Nov 24, 2023 | 9:18 AM
chem_man's Avatar
15 Year Member
I have no suggestions on how to drop the fuel tank/raise the bed - sorry.
Try https://www.dormanproducts.com/ for fuel tank straps, and price the fuel pump and straps at rockauto.com and save some $$$.
Good Luck!
Old Nov 28, 2023 | 10:17 PM
jw11432's Avatar
For what it's worth, I did the fuel pump access panel mod (cut hole in bed right above pump, welded angle iron brackets, drilled/tapped holes for screws for reattaching). I've managed to fare pretty well with bargain brand fuel pumps, but when it comes to hard to replace pumps, it's understandable to want to pay more for a lessened chance of a problem. That's why I was so interested in doing this mod, because now swapping a pump is a 20-30 minute job.
Old Dec 6, 2023 | 9:24 PM
Player One's Avatar
Drop the bolts on driver side loosen up the passenger side and jack up the bed to have clearance for the pump
scrillacos
May 10, 2023 7:26 PM
harley3348
Nov 14, 2014 9:20 AM
84Camaro_L69
Camaro
May 15, 2014 2:41 PM
braves7pro
Dec 29, 2012 10:38 PM
hfdff
Jul 26, 2010 9:09 PM
