Knock after oil change?
Hey guys, I got a 2006 Silverado 5.3 with 127k miles and yesterday I did an oil change, plugs and plug wires and I used Castrol 5w30 synthetic high mileage. Well at a cold start, and sometimes at a warm start when it’s been sitting a while has a quick knock to it (maybe a couple seconds) then goes away. It’s never done this before, does anybody know what this could be?
Could be a lifter beginning to collapse.
Pull the valve covers and spark plugs. Rotate the engine clockwise using a socket on the crank pulley bolt. As you see valves reaching max lift, pause for a moment and observe the rocker and spring - if the valve starts to close on its own, the lifter is collapsing.
Michael Gillitzer
11
Jan 24, 2013 2:33 PM
mystikalraven
10
Jun 29, 2010 8:10 PM
