2000 cavalier fail emission test with new cat
Hey anyone have any idea what to fix with high NOX ? have replaced the cat. the car doesnt have a EGR, any idea what the car does instead of having an EGR? i was told it that it has a EGR port built into the head is this true? if so can it be cleaned easily?
thanks
thanks
it is for the Drive Clean Test in Ontario Canada, they test tail pipe emissions, I now have a conditional pass and have two years to get this engine to pass. I still have no clue as to what the engine does for a EGR, cant fine any info anywhere
That may be your problem without an egr (exhuast gas recycle) valve could be unburned gas into the exhaust. Did your car come with it originally? If not, you might be grandfathered. No nothing about Canadian emission laws.
it has no EGR, the Haines Manual also states that in the EGR section. But the motor must do something with the gasses. Could it have a drilled port in the head with an orfice to regulate flow? has no one come across this on their engine? I guess i would have to take the engine out to find out but i was hoping to find out more info?
Sorry, it looks like yours was one of those great experiments. With carefully engineered overlap between intake and exhaust valve openings, the EGR valve can be eliminated. That is if the careful balance between intake and exhaust systems remain intact throughout the life of the vehicle. Any attempt to make it "breathe" better on the exhaust side will then interfere with the engineering.
bgkykingpin
Jan 2, 2013 11:39 AM
ericnottelin
Jul 2, 2012 10:03 PM
