S-10 & Blazer 1982-2005
wipers have a mind of there own
Old Dec 8, 2009 | 9:08 PM
gsxr750's Avatar
Default wipers have a mind of there own
whats up guys. hope one of you can help me. my wipers have had this problem for a while, when i turn the wipers on after the cab warms up or its summer they just stop working for no reason or they dont turn off when i want them to. when i hit the washer fluid my wipers keep going for like a minute. i have replaced the lever in the cab with no results. does anybody know whats going on.
Old Dec 8, 2009 | 9:26 PM
MDTAHOE's Avatar
Professional Mechanic
I have seen it happen a few times on blazers. Try tapping on the wiper motor while you are having a problem . If tapping changes the operation of the wipers then there is your problem. Sometimes you can turn them on, tap the motor and it will stop.
Old Dec 8, 2009 | 11:23 PM
gsxr750's Avatar
thanks alot for the fast reply. ill give it a shot and see what happens.
Old Dec 9, 2009 | 12:38 AM
98sRgreat's Avatar
Talking
I have the same problem with my 98 silverado, except once it rains a bit and i need to go use my wipers they wont respond. I can hear a funny buzzing, and nothing wiping. I'll get out and push down, or pull up on the wiper arm, and it works, temporarily... is a gear stripped, or bad motor? idk, but its a temp fix to just get out and beat around, lol
Old Dec 11, 2009 | 8:51 PM
Tommyj's Avatar
Default Wiper
I had a 91 Silverado with the same problem. It turned out to be a defective circuit board in the wiper assembly. It is replaceable and I got mine off ebay. Good luck.
Old Dec 12, 2009 | 1:02 AM
deadmanstheory86's Avatar
sounds like a bad pulse board which is what the guy above was refering to., it is truely a circuit board which controls the speed and time intervals at which the wiper motor turns, that is tucked away behind a plastic cover on the front of the motor fastened by one screw. any auto parts store should have it or be able to get it for around 30 bucks is that i think it cost me. if you are really worried about it you can also get the motor and the pulse board together and not have to worry about anything. good luck
Old Dec 12, 2009 | 7:42 PM
MDTAHOE's Avatar
Even though you can get the wiper control module separately (circuit board). We always do the entire assembly because we can get it quicker.
Old Dec 16, 2009 | 9:53 PM
Bill's Dad's Avatar
throw a new motor in it and be done with it....
Old Dec 31, 2009 | 9:40 PM
stock s10's Avatar
I've got a '96 S-10 that had this same problem, all I did was replace the wiper control module and my wipers started working like they're supposed to.
Old Jan 1, 2010 | 12:51 AM
adam86107's Avatar
I remember back in the 90's a lot of people were having this problem with s-10's and blazers, it was always the motor. Replaced that and the problem was fixed.
glmoore0001
Jul 14, 2014 11:04 PM
kstough
Nov 18, 2011 9:38 AM
Buckhorn
Nov 6, 2011 8:23 PM
SWHouston
Jul 8, 2011 9:21 AM
y2k_knight
Jun 24, 2011 10:02 PM
