Front Impact Sensors
2018 Chevy 1500, hit a deer on the front left corner of the vehicle and the airbags went off. Took it to a local mechanic shop and they replaced every module, sensor, and airbag that needed to be replaced.
After replacing everything the only codes that show up after running a diagnostics test are the following.
B0083- 0 Left Front Impact Sensor - High Voltage / Open
B0084- 0 Right Front Impact Sensor - High Voltage / Open
Both the left and right front impact sensors were replaced 2 different times for a total of 4 new sensors. All connections and wires were checked as well and nothing out of the ordinary. Airbag light still comes on and shows those 2 codes.
Any information?
Thanks in advance.
Any information?
Thanks in advance.
mechanic didn't finish the job. Take it back
well don't be surprised if the mechanic tells you where to stick advice you found on the internet.
I am looking for information not smart *** remarks. The mechanic is a friend of mine and I offered to try and find some information regarding the issue and he was very welcoming of any information I have gave him regarding other problems. Please do me a favor and don't comment unless you have information that I am looking for. Thanks.
I simply stated fact. Like it or lump it. Don't ask for advice, if you don't want to hear it.
If he's a mechanic then he should have access to service information and be able to fix it without help from customers.
Tell him to follow the diagnostic procedure: https://charm.li/Chevy%20Truck/2013/...0Charts/B0083/
Extinct
Avalanche
December 27th, 2023 4:55 PM
blkfleet73
December 27th, 2018 5:52 PM
