1995 Z71 hops in reverse
Old Oct 20, 2009 | 5:00 PM
TheRabidWookie's Avatar
Default 1995 Z71 hops in reverse
Hi , im new here mostly because i need help. when I put my truck in reverse or neutral it will start to shake bad for about ten seconds. it does not do it in drive and does not feel like slippage. any help would be great.
Old Oct 20, 2009 | 7:09 PM
also it will try to creep forward in neutral
Old Oct 20, 2009 | 8:06 PM
silverado08's Avatar
torque converter
Old Oct 20, 2009 | 9:40 PM
thats what I thought but soon realized that the converter is always spinning the same way, so it should do it all the time right
Old Oct 20, 2009 | 9:52 PM
now looking for a broken mount somewhere
Old Oct 21, 2009 | 12:27 PM
cams 98 silverado's Avatar
it... almost sounds like shift linkage is out of whack. just for schlitts and giggles. look at linkage and make sure. ABSOLUTE SURE that its properly adjusted. when you say creeper in neutral, it just sounds like teh linkage is tellin the valve body to push your inner spool valve a little so it sort of engages the clutches and planetary and when it "sort of" grabs gear. that means lots of slippage, them clutches and bands are not liking that much ill tell ya that right now. and if the linkage is ok. well still its slipping and we dont want that no sir. i just have a sneaking feeling the converter is not the issue. since its only a fluid coupler and when you say its a creeper. means valve body is sending pressure to engage. so... look at the linkage. double triple check. let us know.
Old Oct 21, 2009 | 6:30 PM
thanks , ill give that a shot and so what happens. I'll let you know
Old Oct 23, 2009 | 10:34 AM
So I took it all apart and silicone greased everything and it seemed to work . Driving strong for two days now. thanks for the help guys. I can fix anything but I dont mess with trannys!
Old Mar 7, 2010 | 12:42 AM
tcow74's Avatar
Same thing happening to my 1997 Z71. I had the transmission rebuilt 2 weeks before the hopping in rev and neutral, also moving in neutral. Driving it back to the shop, lost all gears. They told me rev clutches were burned up, they repaired, but all the hopping and shaking was coming from my tranfercase, BS. I'll talk to the owner on Monday
snowmass2dr
Feb 25, 2015 4:29 AM
shaffer21
Feb 19, 2015 8:31 AM
95chevyTN
Feb 3, 2014 8:46 PM
Morphsuit
Oct 8, 2013 6:06 AM
firelance911
Mar 11, 2011 8:22 AM
