Help Tranny Removal
Old Apr 18, 2008 | 5:40 PM
GhoSt1985's Avatar
Default Help Tranny Removal
Hey Guys/Girls
Im new here. Signed up because I cant get this stupid transmission off. I went to the dealership parts and they didn't anything. Other then having to buy new tools. Soo.... Just to be on the safe side. Can some one help me out here? This is what I got so far. Took off all the bolt I could see from the housing (dunno if thats how its spelled). But these two are the only ones left.
So, is there a special tool to remove these two? Tried my sockets but none of them fit. Will appreciate any help.
Thanks for view and helping
Jesse
PS This is a standard transmission on a 93 Chevy 2500.
[IMG]local://upfiles/17351/7FD547CC81284FC9B0D20EB252757B75.jpg[/IMG]
Old Apr 18, 2008 | 5:57 PM
jwko's Avatar
Default RE: Help Tranny Removal
Hi, im new to the forum also. Those are not bolts, those are just alignment dowel pins.
Old Apr 18, 2008 | 6:03 PM
GhoSt1985's Avatar
Thanks jwko
So ive taken all the bolts i could find and the housing still wont move im pretty much giving up and about to break the bitch off lol any ideas what might be the solution???????
Old Apr 18, 2008 | 6:15 PM
northey87's Avatar
Not sure what the solution should be, but welcome to the forum, both of you!!!
Old Apr 18, 2008 | 8:44 PM
jwko's Avatar
Thank You Northey.
Could the clutch fork be holding it by chance?
There should be 6 bolts holding the bellhousing in
Old Apr 18, 2008 | 9:45 PM
shawnvw's Avatar
Banned
soak em down with WD40. try to wedge a big screwdriver or pry bar in there and slowly work it side to side. Careful not to crack the housing though
Old Apr 19, 2008 | 11:46 AM
06chevy5.3's Avatar
ya its not just going to come off, you will have to work it off, try doing what shwnvw said, that should work, welcom to the forum
Old May 8, 2008 | 8:14 PM
GhoSt1985's Avatar
Hey guys,
Thanks for the help, and sorry for the late reply. Now I have another question. I got the bellhousing off. All I had to do is pwn it out. But now question is, how do we bleed a hydro clutch?
Asking because Iv tried bleeding it from the slave cylinder and the clutch seems to get stiffer but when I turn the truck on the clutch gets soft and I can't get the gears to go in. I ended up replacing both master and slave cylinder. Can't seem to figure out.
Ill turn the truck off and put it in gear. Turn the truck on with the clutch pressed and the truck wont move. But if I try to put in gear before I turn it on, it wont go in.
Please help...
Thanks
Jesse
A. T
Nov 29, 2011 5:03 PM
DeHartShadow
Mar 28, 2010 10:10 PM
89silverado283
Feb 16, 2010 8:50 AM
revamped
Aug 24, 2008 10:48 PM
revamped
Jan 23, 2008 4:03 PM
Top
Follow Us
