Chevrolet Aveo 2013 T300 won't start
I need some advice (I hope I am in the right forum section). After changing the oil filter, the car does not start. The starter works, the engine is trying to catch, but runs irregularly and then stops. Could you advise me what the problem is? The oil in the car is new and optimal volume as well. Candles are new and OK. I have a fault code 128 in the info panel, but I don't know if it has anything to do with it, it has something to do with cooling: https://www.700r4transmissionhq.com/p0128-chevy-aveo/
Any help much appreciated.
Possible causes Leaking or stuck open thermostat
Low engine coolant level
Insufficient warm up time
Faulty engine coolant temperature sensor
Engine coolant temperature sensor harness is open or shorted
Engine coolant temperature sensor circuit poor electrical connection
@oilcanhenry Thank you. Can you tell me if these issues can cause this strange engine behaviour? I want to find out if P0128 is the cause of this or not.
cupofchicken
December 24th, 2011 8:28 AM
STEVE311
September 27th, 2009 12:27 PM
