Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Chevrolet Aveo 2013 T300 won't start
Old Nov 14, 2019 | 2:23 PM
TomCHA13's Avatar
Default Chevrolet Aveo 2013 T300 won't start
I need some advice (I hope I am in the right forum section). After changing the oil filter, the car does not start. The starter works, the engine is trying to catch, but runs irregularly and then stops. Could you advise me what the problem is? The oil in the car is new and optimal volume as well. Candles are new and OK. I have a fault code 128 in the info panel, but I don't know if it has anything to do with it, it has something to do with cooling: https://www.700r4transmissionhq.com/p0128-chevy-aveo/
Any help much appreciated.
Old Nov 15, 2019 | 12:47 AM
oilcanhenry's Avatar
The full information on an OBD II P0128 code are:
Possible causes Leaking or stuck open thermostat
Low engine coolant level
Insufficient warm up time
Faulty engine coolant temperature sensor
Engine coolant temperature sensor harness is open or shorted
Engine coolant temperature sensor circuit poor electrical connection
Old Nov 15, 2019 | 4:53 AM
TomCHA13's Avatar
@oilcanhenry Thank you. Can you tell me if these issues can cause this strange engine behaviour? I want to find out if P0128 is the cause of this or not.
Old Nov 17, 2019 | 4:43 AM
It is possible but my guess is that your motor should run even with a P0128 code on. Perhaps something came loose during the oil change or it was simply a case of unfortunate timing? A bad 02 sensor perhaps, but that would allow for a different OBD II code, should that be the case.
kjjb0204
Sep 4, 2018 4:07 PM
Cavtrouble
Aug 6, 2013 1:22 AM
Clark317
Feb 8, 2012 11:03 PM
cupofchicken
Dec 24, 2011 8:28 AM
STEVE311
Sep 27, 2009 12:27 PM
