1999 Surburban Heads
Old Jan 25, 2009 | 10:25 AM
dogman1313's Avatar
Default 1999 Surburban Heads
I have an antifreeze leak at the top of the engine, it looks like its at the front of the engine on the passenger side by the front 2 bolts of the intake manifold. What is the easiest way to replace the head gasket? I know if I take it to a shop it will be very expensive.
Thanks in advance
Old Jan 25, 2009 | 2:15 PM
SabrToothSqrl's Avatar
Default head gasket
is the 99 still a 350?
http://wiki.answers.com/Q/How_do_you...et_on_1999_350
Old Jan 25, 2009 | 4:08 PM
Red Dog's Avatar
Thanks in advance
Are you not looking to replace the intake manifold gasket? There was a known problem on 5.7 L engines from 1996 to 1999. I had to have this done on both of my vehicles. Yes, it is costly. On the bright side, neither one has had an issue since.
Good Luck,
-JR
Old Jan 25, 2009 | 8:11 PM
dogman1313's Avatar
Good Luck,
-JR
Are you saying that antifreeze can leak from the intake gasket?
Old Jan 26, 2009 | 7:25 PM
Red Dog's Avatar
Yes, I am. When the gasket fails, the coolant can either get into the oil, or leak to the outside. In both of my cases, it leaked on the passenger side of the engine towards the rear. Fortunately, not into the oil.
-JR
Old Jan 28, 2009 | 8:41 AM
jcbrock's Avatar
I had a slow coolant leak on my '97. It was driving me crazy, I couldn't find it anywhere. I read about the intake manifold gasket and took it in to have it tested and repaired. Sure enough there was a pin hole in the back of the gasket, leak fixed. Total cost of repair was close to $800 (he found a couple of other problems while he was in there).
Old Jan 28, 2009 | 9:06 AM
Unhappy
Same here, a 97 Tahoe had the intake leak, you'd think they would have a service bulletin on it. Any competent shop will be able to fix you up, it will take several hours to repair and $600-800 in cost, mostly time not parts….
Old Jan 28, 2009 | 12:17 PM
Red Dog's Avatar
It cost me $700 for each of mine for the job. I had them replace the distributor cap and rotor since there was so much removed to do the gasket.
-JR
Old Jan 29, 2009 | 8:23 PM
dogman1313's Avatar
Thanks for the info, I thought it was only the head gaskets.
RA111125
Oct 13, 2009 12:55 PM
Bc1980
Aug 7, 2009 8:36 AM
aquaholic
Sep 28, 2008 7:54 AM
1604neil
May 19, 2007 9:55 AM
1604neil
Feb 16, 2007 6:29 PM
