2000 sub is cooking us
At first I noticed that the blender motor was not moving anymore. Got a new one. I then realized that I am getting hot air no matter what position the blend door is in.
what could be causing this? I am pretty sure that the blend door is still there, as it takes a little bit of finger force to move it. Besides; where would it go?
is it correct that it should only move about 40 degrees?
I had to replace a blend door actuator on both my 1994 Suburban and 2005 Yukon.
Maybe temporarily move into the "cold" position and leave the harness/actuator uninstalled.
I think the repair will be $300-$400 at a shop.
Guess I will have to take the whole thing apart now…
This happened on our 2005 Yukon a couple of years ago, and sometimes the blower fan would not operate at all. I decided to let independent shop have a go at it, a shop I've used and trusted for 15 years. Mechanic said not too uncommon, that blower resistor and blower motor can be intermittent and take out the other. I went with his experience, and replacing both fixed that. Yes, cost was about $400, factory parts.
Not sure on your year but my '11 has several temp. sensors in the system to monitor / control HVAC temps in the auto system. A scan of them may turn up a bad sensor if the a/c has a full charge and putting out full cooling.
Javier Sanchez Tamburrino
May 27, 2017 9:49 PM
tsss795
Apr 4, 2011 6:39 PM
