2007 Tahoe tank vent valve
Old Sep 4, 2021 | 3:30 PM
LarryE's Avatar
Default 2007 Tahoe tank vent valve
Gas tank was not taking gas when empty so I changed that vent valve assemble above the spare tire.That didn't fix the problem.Any other ideas? Tahoe 2007 Z71 5.3LThanks.
Old Sep 6, 2021 | 1:02 PM
sisko200's Avatar
Give this a read.
https://chevroletforum.com/forum/tah...roblems-57123/
Old Sep 6, 2021 | 1:23 PM
GLKustoms's Avatar
Disconnect the line on the purge valve at the engine. If charcoal pellets come out, the charcoal canister is bad, and the lines will need to be flushed.
Old Sep 6, 2021 | 2:37 PM
LarryE's Avatar
Thanks Sisko200 and GL.I have read that whole thread twice.After the tank vent valve didn't work I blew out the vent line from the filler neck to the charcoal canister.Today I tried again today (tank was 3/4 full) to fill it up .Same problem.I am trying to do the easy things first.I will check the purge vale line next like GL said.Thanks again.
Old Sep 6, 2021 | 4:33 PM
disconnect the line from the tank to the cannister and do a fill up. if its fills the vent line is still blocked.....the line from the tank to the cannister out the vent solenoid out to the vent filter must be clear.
blow thru the cannister...any restriction?
Old Sep 6, 2021 | 4:57 PM
LarryE's Avatar
Thanks tech2,I will try that also.
Old Sep 7, 2021 | 9:40 PM
LarryE's Avatar
Tech2,I didn't have time to do your idea tonight but I will on Saturday.GLKustom,I did your idea tonight.I disconnected the line from the charcoal canister to the engine purge valve while at the gas station.Seven or eight bits of charcoal fell in my hand.With the line disconnected it seemed a little easier to fill it up, but not much.Might have been my imagination.I guess the charcoal canister has come apart.I guess the best thing to do is to replace the canister and blow out all the lines while they are disconnected.
Old Sep 13, 2021 | 8:45 PM
LarryE's Avatar
Well,update on my 07 Tahoe on getting the tank to take gas to help anybody else.Saturday I managed to get all 3 of the vent lines off the charcoal canister without breaking any of them.As soon as the vent line from the tank was disconnected charcoal was falling out.I dropped the canister and charcoal was pouring out of it.The line from the tank had a lot of pellets in it I just kept blowing air in till no more pellets came out.I put everything back together and went to the gas station.The tank was at 3/4 but it filled up normally.Tonight my daughter came by with 1/4 tank.At the gas station it filled up normally.Long story short, drop the canister, blow out the large line from the tank and that should fix it.
Old Jun 22, 2024 | 8:22 PM
Pheonix rum's Avatar
Default Did you disconnect from the tank too
did you take the lines of the tank too or just the canister?
Old Jun 28, 2024 | 7:24 PM
LarryE's Avatar
Well, it was a while back but I don't think I disconnected any tank lines. I know I didn't drop the tank. I did disconnect the purge line up in the engine compartment and blow air into it.
Brandy Roberts
Oct 15, 2017 9:26 AM
WFM1951
S10 & Blazer DIY and Useful Threads
Apr 22, 2017 2:19 PM
mwkoenig
Jan 16, 2017 8:34 PM
dcoperator
Apr 17, 2016 10:45 PM
Duece1123
Jan 17, 2014 7:39 PM
