Rear wiper/washer stopped working
As posted, you need a voltmeter or at least a test light. Locate the plug on the motor with wiper switch on, fues in, you should have battery voltage at the plug. If so, motor, if not, it is an open circuit.
Thanks for the replies.
Perhaps I should have remarked that I'm equipped and knowledgeable in troubleshooting. I'm trying to save myself the work of tracing the entire circuit out if this happened to be a common problem with a known solution.
Since both the washer and the wiper stopped working that seems like a pretty good clue. I rarely use either one of them and it was only by accident that I discovered the situation. With no schematic I'm groping in the dark.
Both washer motors were cracked and leaking, so I replaced them both. Now the rear motor comes on, but no fluid is coming out. The front motor does not even turn on, but the wipers all work.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
