Starter wont turn
Old Sep 6, 2025 | 9:44 AM
rblvacation's Avatar
Default Starter wont turn
My van starter wont turn, but I have full battery power and car was running until I turn it off. I noticed a bunch of wires are disconnect, do you guys know what these wires are. They are in a bundle near the front bulkhead and a connector. See pictures
Old Sep 6, 2025 | 10:02 AM
Triaged's Avatar
Likely for an old car alarm. Good luck rewiring your van.
Old Sep 6, 2025 | 10:25 AM
Rednucleus's Avatar
Try tapping the starter with a hammer (lightly)while someone holds key in start position. If it goes, replace the starter. What vehicle, year etc? Original starter still??
Old Sep 6, 2025 | 10:29 AM
My van is 2010 3500 Savana, I started it and the engine run..took it for a 20 miles ride and stop and turn of and when I crank..just silent..all other electrical system is ok. Anyone has a similar van and can see what those wires suppose to go. I suspect they came lose and cause the starting issue
Old Sep 6, 2025 | 12:25 PM
Triaged's Avatar
https://charm.li/Chevrolet/2010/Expr...tem%20Diagram/
I guessed that you have a 6.0l but I bet the 4.8l is identical. The Duramax is likely different.
Old Sep 6, 2025 | 6:26 PM
Rednucleus's Avatar
I'll bet those wires have been that way for a long time and are not the issue
Old Sep 7, 2025 | 11:28 AM
Old Sep 9, 2025 | 3:58 PM
Derrick71's Avatar
You can hot wire the starter to test it out. Just give it 12v to where the smaller of the two power lines connect. The fat line is the power and the smaller line signals it to run when 12v is applied.
Old Sep 9, 2025 | 4:11 PM
So what happened is that I make a copy of the original key and try that to start I didn't know that the original key has some kind of transponder that would allow the van starter to turn but if you make a copy you can still open the door and turn on ACC but the starter wont engage. My original key look very simple and flat and has no key fob but look like the transponder chip is embedded into the key handle. So now the van is starting just fine
L84sky
Apr 11, 2023 11:38 AM
Jay28Rich
Jul 23, 2022 12:29 PM
SouthernChevy74
1988 - 1998 (GMT400)
May 29, 2021 8:53 PM
Yoga Chou
Sep 12, 2015 12:46 AM
Skusty
Jun 19, 2011 1:03 PM
