Constant ignition
I have a 1999 Chevrolet Suburban 1500 lt (not 4 wheel drive) and when I connect my starter the red wire makes it continuously crank without the key in the ignition. I thought it was my solenoid but I connected a switch to it and to my battery and my car turns on just fine but when I connect the wire that connects to my cars ignition switch it constantly try’s to run. Please help thanks.
Bad ignition switch?
Cables crossed?
Let me know.
Cables crossed?
Let me know.
This started on its own. I had to replace the starter because the solenoid was toast, and the starter sounded like a box of chicklets when I shook it. I also found that the 60 amp fuse at the battery junction box was blown. I replaced it, but still am not getting any voltage reading on the solenoid wire. Am going to trace the wires inside the cab in the morning and see if I can find any fusable links or fuses under the dash
To tell you the truth, it bugs me more when the very first post that someone does is asking about a problem instead of the introduction.
